Zynq embedded acceleration - "XILINX_XRT must be set"
I'm trying to make Vitis hw-accelerated project. I have managed to build and compile simple vector addition program from samples but after copying files it seems that I can't run program.
How can I fix this error? Can you tell me or/and provide links?
I have copied new generated "rootfs", image.ub, BOOT.BIN, and system.dtb (screenshots) and when trying to run script from home I'm getting that error.
Screenshot from 2020-01-26 14-22-03.pngScreenshot from 2020-01-26 14-22-28.pngScreenshot from 2020-01-26 14-23-30.png
Thanks for help!
Re: Zynq embedded acceleration - "XILINX_XRT must be set"
try this
export XILINX_XRT=/usr
try this
Thanks! it semi-worked now Im stuck at another error...
Do you know why it says that there is no devices?Screenshot from 2020-02-11 01-35-16.png
