custom struucture problem
I have a structure :
typedef struct point
    float x[320]
} D_point
I define a variable in my kernel like this:
D_point example
I wonder does the compiler use register or Bram to create this "example"?
Is there a pragam(like #pragma HLS array_partition) that can patition the "example" to make all the elements be accessed in parallel?
Tags (2)
Re: custom struucture problem
There is no way to directly specify an array as registers. What you can do is to use 'array_partition complete' pragma to achieve that, like you already pointed out.
HLS tool will decide if it is implemented in URAM/BRAM or LUTRAM(LUT and FF), if you would like to manually specify it, you may use below pragma:
#pragma HLS resource variable=x core=RAM_1P (The available core selections are available in HLS GUI)
@yunl
Thaks for your reply.
The GUI mentiones there are several memory choice:
-memory_style (auto|distribute|block|uram)
But I think all of them arr ram type.
What I want is spliting every element of the structure into to a single register.
Then I can accees all the elements simultaneously just like the ( #pragma HLS array_partition complete ) does.
Can i achieve that?
