error "internal stream in a non-daraflow region" ?
Error and source code below.
I get this error only outside the top function.
Why is that?
Note that the error is given for ALL streams in there.
Doing Emulation-HW in SDx
Xilinx SDx v2019.1.3 (64-bit)
SW Build 2644227 on Wed Sep 4 09:44:57 MDT 2019
ERROR: [XFORM 203-733] An internal stream 'myW8Streams.V.0' with default size is used in a non-dataflow region, which may result in deadlock. Please consider to resize the stream using the directive 'set_directive_stream' or the 'HLS stream' pragma.
typedef unsigned long long Word;
static hls::stream<Word> inStream;
static hls::stream<Word> myW4Streams[4], myW8Streams[2];
#pragma HLS DATAFLOW
readStreams(mem, numWords, inStream);
splitStream(inStream, numWords, myW4Streams);
compute1(myW4Streams[0], myW4Streams[1], numWords/2, myW8Streams[0]);
compute1(myW4Streams[2], myW4Streams[3], numWords/2, myW8Streams[1]);
Tags (3)
