Visitor hanqiu
error using hls stream pragma
This is part of my code:
hls::stream<in_type> a_stream[N][N];
#pragma HLS STREAM variable=a_stream[0][0] depth=3
This is the error message:
CRITICAL WARNING: [HLS 200-70] In file included from /home/hqiu/systolic_gemm_bi/_sds/vhls/systolic_gemm_bi/solution/.autopilot/db/systolic_gemm_bi.pragma.1.cpp:1:
In file included from /home/hqiu/systolic_gemm_bi/systolic_gemm_bi.cpp:1:
/home/hqiu/systolic_gemm_bi/systolic_gemm_bi.cpp:28:19: error: calling a private constructor of class 'hls::stream<ap_uint<32> >'
_ssdm_SpecStream( a_stream[0][0], 0, 3, "");
/opt/Xilinx/SDSoC/2016.2/Vivado_HLS/2016.2/common/technology/autopilot/hls_stream.h:91:43: note: declared private here
    inline __attribute__((always_inline)) stream(const stream< __STREAM_T__ >& chn):V(chn.V) {
/home/hqiu/systolic_gemm_bi/systolic_gemm_bi.cpp:28:19: error: cannot pass object of non-POD type 'hls::stream<in_type>' through variadic function; call will abort at runtime [-Wnon-pod-varargs]
Compilation of the preprocessed source 'systolic_gemm_bi.g' failed
    while executing
"source /home/hqiu/systolic_gemm_bi/_sds/vhls/systolic_gemm_bi_run.tcl"
    invoked from within
"hls::main /home/hqiu/systolic_gemm_bi/_sds/vhls/systolic_gemm_bi_run.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
ERROR: [SDSoC 0-0] Exiting sds++ : Error when calling '/opt/Xilinx/SDSoC/2016.2/Vivado_HLS/2016.2/bin/vivado_hls /home/hqiu/systolic_gemm_bi/_sds/vhls/systolic_gemm_bi_run.tcl'
sds++ log file saved as /home/hqiu/systolic_gemm_bi/_sds/reports/sds_systolic_gemm_bi.log
ERROR: [SDSoC 0-0] Build failed
sds++ completed at Mon Nov 14 22:39:18 CST 2016
Tags (2)
Re: error using hls stream pragma
Hi hanqiu,
As far as I know, you cannot declare an "array of streams" like you are trying to do. You would have to individually declare a separate variable for each, with a separate pragma for each.
hls::stream<in_type> a_stream0;
hls::stream<in_type> a_stream1;
... #pragma HLS STREAM variable=a_stream0 depth=3
#pragma HLS STREAM variable=a_stream1 depth=3
Sam
Hi hanqiu,
Sam
