hw_emu issue
I have a project compiled successfully in both sw_emu and hw_emu modes with SDAccel 2017.1 in centos7.2. It also runs through sw_emu.
But in hw_emu, the console shows such msgs, (NO errors show up):
INFO: [SDx-EM 22] [Wall clock time: 12:18, Emulation time: 0.0865756 ms] Data transfer between kernel(s) and global memory(s)
BANK0          RD = 0.609 KB               WR = 0.000 KB
BANK1          RD = 0.000 KB               WR = 0.000 KB
BANK2          RD = 0.000 KB               WR = 0.000 KB
BANK3          RD = 0.000 KB               WR = 0.000 KB
INFO: [SDx-EM 22] [Wall clock time: 12:23, Emulation time: 0.173906 ms] Data transfer between kernel(s) and global memory(s)
INFO: [SDx-EM 22] [Wall clock time: 13:00, Emulation time: 0.785315 ms] Data transfer between kernel(s) and global memory(s)
CRITICAL_WARNING: [SDx-EM 21] Write for argument "kernel_align:numAlignments" to global memory has not completed in 230000 cycles. The device may have hung. Please check your kernel behavior
CRITICAL_WARNING: [SDx-EM 21] Write for argument "kernel_align:seqs" to global memory has not completed in 230000 cycles. The device may have hung. Please check your kernel behavior
INFO: [SDx-EM 22] [Wall clock time: 13:05, Emulation time: 0.872743 ms] Data transfer between kernel(s) and global memory(s)
In this window, it seems there is error. but I don't what does it mean.
Re: hw_emu issue
Hi @sl_cgi
You might want to check the communication between kernel and global memory, e.g. the size of each transfer and the number of read/write transactions. When possible, try to use burst transfer instead of small piece of data transfer once at a time, which may cause such critical warnings in hw-emu.
Joyce
Re: hw_emu issue
Hi @sl_cgi
From the log we can see the kernel read in 609 Bytes from global memory and there is no output. The kernel seems like stalled.
For one function call of kernel, it the data size to be input is larger than 609 Bytes,  the kernel may have stalled at input stage.
For example if the read FIFO /stream become full, the design halt operation because it is unable to further read in data.
If 609 Bytes is exact the input data size, then the halt may happened at downstream stages.
You can use printf to print out valuable value and debug the issue.
If you have knowledge of Verilog/VHDL coding and Vivado Simulation, you can also debug kernel through RTL waveform during HW_EMU.
To launch RTL waveform, you need to switch on the option "Use RTL waveform for kernel debugging" in Run Configurations.
You may also share your code to gain help from others.
Sean
Visitor luckyxiuxiu
Re: hw_emu issue
I have met the similar problem.Have you solved this ? My kernel read in data ,but no output.There is nothing in profile report and Application timeline file.
Re: hw_emu issue
Hello luckyxiuxiu,
How long did you run your application in HW Emulation. And did it complete. Until the application completes, the timeline report will not be available.
Amit
Re: hw_emu issue
Hi @sl_cgi
Joyce
Re: hw_emu issue
Thanks very much.
Used local buffer to hold the results, then burst transfer the results from local buffer into global memory.  Now the problem was fixed.
@luckyxiuxiu you can try this approach as well.
