mapping kernel ports to global memory
Im working on ALVEO U250 card, where im working on Vadd example to understand the vitis flow. The ports of Vadd are getting mapped to DDR[0] interface by default , i want to change the port mapping and utilise all the global memories.
[connectivity]
sp=krnl_vadd.m_axi_gmem0:DDR[0]
sp=krnl_vadd.m_axi_gmem1:DDR[1]
sp=krnl_vadd.m_axi_gmem2:DDR[2]
I used this connectivity.sp option which is mentioned in UG 1393 document but still it is using only one DDR.
Data transfer between kernel(s) and global memory(s)
krnl_vadd_1:m_axi_gmem0-DDR[0] RD = 16.000 KB WR = 0.000 KB
krnl_vadd_1:m_axi_gmem1-DDR[0] RD = 16.000 KB WR = 0.000 KB
krnl_vadd_1:m_axi_gmem2-DDR[0] RD = 0.000 KB WR = 16.000 KB
In document it is mentioned that
During v++ linking, use the connectivity.sp option in a config file to map the kernel port to the desired memory bank.
There is no config file with .cfg extention. i can only find config-common.ini file. please help me out.
Prashanth.
Re: mapping kernel ports to global memory
You don't touch the auto-generated .ini files. Instead, you can create a file (any extension, .ini, .cfg, .txt...) with the connectivity options and then specify --config <your created configuration file> in v++ linker options.
Hi @mdpuma ,
you can use the host_global_bandwidth example as reference :
https://github.com/Xilinx/Vitis_Accel_Examples/tree/e2ea58df09d123214fb0d814fe605a412d146625/host/host_global_bandwidth
Following is the ini file where two banks are used(DDR[0], DDR[1]) :
https://github.com/Xilinx/Vitis_Accel_Examples/blob/e2ea58df09d123214fb0d814fe605a412d146625/host/host_global_bandwidth/krnl_host_global.ini
Need to add the ini file to ldclflags in Makefile:
https://github.com/Xilinx/Vitis_Accel_Examples/blob/e2ea58df09d123214fb0d814fe605a412d146625/host/host_global_bandwidth/Makefile#L75
Vishnu
Hi @bchebrol
Thanks a lot for your reply . The make file which is there in github kernel_vadd example is not matching with the make file generated by the vitis tool.
https://github.com/Xilinx/Vitis_Accel_Examples/blob/e2ea58df09d123214fb0d814fe605a412d146625/rtl_kernels/rtl_vadd/Makefile
I have attached the make file generated by the tool and also i attached the screenshot of the .ini file  . There are several .ini files im confused which .ini file i should use.  please kindly look into this issue. ini file.png
Thanks & Regards
Prashanth.
Hi @mdpuma ,
you see different ini files for each of the flows(Software Emulation, Hardware Emulation and Hardware). That is the reason you see several .ini files.
Vishnu
Hi @bchebrol
As you told , I understood that .ini file will be generated for software emulation, hardware emulation and target hardware .  Would you please let me know in which .ini file I should write  connectivity.sp to map the global memories.
Thanks and Regards,
Prashanth.
@gracesThanks a lot man.It worked..
Prashanth
Hi @graces
please clarify my doubt, I have given config file and build the hardware emulation and run it , then all the three DDRs as i mentioned in config file is being access by krnl_vadd input arguments . Below attachment-1 is the system diagram generated by vitis analyzer. I used the same config file in target hardware and built it. Then in vitis analyzer is showing that only one DDR is being accessed by krnl_vadd inputs. Please check the attachment 2 below. Can you please tell me if any specific reason for that?13.png
        fig : attachment-1
                                               fig : attachment 2
 Que(2):
If I want to transfer the data from host to specific address location of  DDRs , I need to access the address locations of DDRs from host code.  In vitis analyzer base addresses of DDRs are given , can i use them in host code to transfer the data to/from DDRs.
Prashanth.
