memory alignment when allocating emmory in SDAccel
I have an integer array, but I want to access it with 512bit port in SDAccel.
But how can I have the memory allocated in device memory to be aligned to 512bit i.e. 64Byte?
I am using xcl_malloc() to do the device memory allocation and seems there is no
option for aligning the address.
Re: memory alignment when allocating emmory in SDAccel
Device memory is 4096 bytes aligend.
For host, check example code like
    size_t vector_size_bytes = sizeof(int) * LENGTH;
    std::vector<int,aligned_allocator<int>> source_a (LENGTH);
    std::vector<int,aligned_allocator<int>> source_b (LENGTH);
in https://github.com/Xilinx/SDAccel_Examples/blob/master/getting_started/misc/vadd/src/host.cpp
brucey
brucey
