Visitor mouhamedmbr
note: candidate function template not viable: requires 3 arguments, but 5 were provided
error :note: candidate function template not viable: requires 3 arguments, but 5 were provided
void dut_mmult_accel_core (
template <typename T, int DIM1,int DIM2,int DIMa,int DIMb,int DIMc,int DIMd,int DIMe,int DIMf, int SIZE, int U, int TI, int TD>
	AXI_VAL in_stream[SIZE],
	AXI_VAL out_stream[3*SIZE],
	//volatile ap_uint<1> *hw_trig)
	 volatile   ap_uint<1> *predict_label1_hw_trig;
	 volatile	ap_uint<1> *precision1_hw_trig;
	 volatile	ap_uint<1> *prob_estimates_t1_hw;
// Map ports to Vivado HLS interfaces
#pragma HLS INTERFACE ap_fifo port=in_stream
#pragma HLS INTERFACE ap_fifo port=out_stream
	// Map HLS ports to AXI interfaces
#pragma HLS RESOURCE variable=in_stream  core=AXIS metadata="-bus_bundle INPUT_STREAM"
#pragma HLS RESOURCE variable=out_stream core=AXIS metadata="-bus_bundle OUTPUT_STREAM"
#pragma HLS RESOURCE variable=return core=AXI4LiteS metadata="-bus_bundle CONTROL_BUS"
	ap_uint<1> logic_zero = 0;
	ap_uint<1> logic_one = 1;
	T LabelS [DIM1][DIM2];
    T out predict_label1[DIMa][DIMb];
	T out precision1[DIMc][DIMd];
	T out prob_estimates_t1[DIMe][DIMf];
	*predict_label1_trig = logic_zero;
	*precision1_trig = logic_zero;
	*prob_estimates_t1_trig = logic_zero;
	assert(sizeof(T)*8 == 32);
	*predict_label1_trig = logic_one;
	*precision1_trig = logic_one;
	*prob_estimates_t1_trig = logic_one;
Scholar u4223374
Re: note: candidate function template not viable: requires 3 arguments, but 5 were provided
I'mn not sure, but I suspect that it's just because you've got semicolons after your last three arguments. All except the last should have a comma, and the last should have nothing.
Scholar u4223374
