reVISION demo on ZCU102 ERROR: vlib_init failed: connector supports no mode
Hi, All,
I follow the steps http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide+2017.2 to do the demo on zcu102 for reVISION, but got the error ERROR: vlib_init failed when type in of2.elf . I have refer https://forums.xilinx.com/xlnx/board/crawl_message?board.id=ultrascale&message.id=4618 and type in of2.elf -s 1 -m 2 -d 1 but stiil failed. Who can help me?
Thanks very much
Re: reVISION demo on ZCU102 ERROR: vlib_init failed: connector supports no mode
Hi, Jose,
after I changed the command from "stv.elf -s 2 -m 2 -d 1 -i 3840x1080 -o 1920x1080 -filter-sv-cam-params /media/card/SN15284.conf" to "stv.elf -s 2 -m 2 -d 1 -i 3840x1080 -o 1920x1080 --filter-sv-cam-params /media/card/SN15284.conf", it works well. Thanks a lot.
I use the hardware is HW-Z1-ZCU102 REVISION 1.1
Is this a copy of the SD card image?
Check the pre-built image SD copies on the SD card.
Austin Lesea
Principal Engineer
Xilinx San Jose
Dear ,
Yes, I just copy the demo from the ZCU102 Production Silicon reVISION Package: Includes SDSoC platform, design examples, and pre-built SD card images
And there is another one ZCU102 ES2 Silicon reVISION Package: Includes SDSoC platform, design examples, and pre-built SD card images. May I know how to seperate "ZCU102 Production Silicon reVISION Package" and "ZCU102 ES2 Silicon reVISION Package"? Is that I should use ZCU102 ES2 Silicon reVISION Package?
Thanks a lot.
Check what identifies when you connect the JTAG-USB and bring up hardware manager.
Or, look at the shipment papers for your board.
Depending on how old it is, it is ES1, ES2, or production.
You do require the correct image for the board (ES2 will not work for production, and vice-versa).
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi, local service told me this is production on my hand. So I should use ZCU102 Production Silicon reVISION Package.  But it still error when I type in of2.elf. And I try to run anther demo Stereo Vision still failed. I have connected ZED for capture and monitor 1920x1080. When booting I found the following message:
[   15.833184] usb 2-1: Manufacturer: Leopard
[   15.844805] uvcvideo: Found UVC 1.00 device ZED (2b03:f580)
[   15.853559] uvcvideo 2-1:1.0: Entity type for entity ZED was not initialized!
[   15.860640] uvcvideo 2-1:1.0: Entity type for entity ZED was not initialized!
[   15.867748] uvcvideo 2-1:1.0: Entity type for entity Camera 1 was not initialized!
Then:
Starting Telephony daemon
Starting tcf-agent: OK
Setting console loglevel to 0 ...
/bin/autologin: line 1: -e: command not found
root@zcu102_base_trd:~# ^C
when I write command: stv.elf -s 2 -m 2 -d 1 -i 3840x1080 -o 1920x1080 -filter-sv-cam-params /media/card/SN15284.conf
the message out is:
root@zcu102_base_trd:~# stv.elf -s 2 -m 2 -d 1 -i 3840x1080 -o 1920x1080 -filter-sv-cam-params /media/card/SN15284.conf
Invalid frame rate 'ilter-sv-cam-params'
So, Can you guid me how to run a success demo? thanks a lot.
OK,
I use
of2.elf -o 1920x1080
after I login.
My display is on the DP port.  Both display and my Leopard MIPI camera support 1920x1080 (they must match in the of demo).
From your log, it does not seem to find the camera?
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi, Jose,
