Participant rookie@meteor
sds_allloc memory access
How can we access the memory allocated by sds_alloc in the PS. Say if we want to copy data to and from that buffer pointer. I'm trying to access them directly which throws an error saying Illegal memory access. Can somebody please shed more light on this. I'm using SDSoC 2017.4 and using the zcu102 MPSoC.  Can I do something like this :
(int * )buf_ptr = (int *) sds_alloc();
for(i=0;i<iter;i++)
buf_ptr[i] = something;
OR use functions like memcpy,etc.
will the pointer arithmetic be valid after typecasting.
Thank You
Re: sds_allloc memory access
Hi rookie@meteor,
accessing pointer which is created using sds_alloc() should be same as created using malloc(). Please refer below example:
https://gitenterprise.xilinx.com/SDSoC-Examples/apps/blob/master/cpp/getting_started/hello_vadd/src/main.cpp
It is creating pointers using a,b, and hw_results using sds_alloc()  and pointer gold using malloc. And initializing same them same way.
you can use memcpy as well.
-Heera
Hi rookie@meteor,
-Heera
