Visitor yunzhehi
sdx2017.4 XOCC kernel compiler cannot set --kernel_frequency?
HI,
   when I use sdx2017.2, I can set the XOCC kernel compiler frequency with "--kernel_frequency=200" to change the default frequency.
   now use the sdx2017.4, it seems the "--kernel_frequency=200" just ignored in the compiler.
   is it a bug? or sdx2017.4 has other methods to set kernel frequency?
Re: sdx2017.4 XOCC kernel compiler cannot set --kernel_frequency?
Hi, @yunzhehi ,
It's an issue in Sdx 2017.4, which has been fixed in Sdx 2018.2.
To workaround the issue, you can set period in a tcl file and execute it before hls:
TCL content:  create_clock -period <kernel_frequency>Hz -name default
option: --xp prop:solution.hls_pre_tcl=hls_hook.tcl
Please refer to the below discussion:
https://forums.xilinx.com/t5/SDAccel/2017-4-Sdaccel-Ubuntu16-03-XOCC-Options-kernel-frequency-problem/m-p/823160#M1664
Visitor yunzhehi
I viewed the discussion, but seems not the same problem.
I tried to change frequency in compiler not linker, I want to change default frequency in HLS result, not SYN/PLACE/ROUTER.
do you have any suggestion?
The option you use is "--kernel_frequency=200"
Have you tried:  "--kernel_frequency 200"
Visitor yunzhehi
"--kernel_frequency 200" does not working too. It seems the compiler just ignore --kernel_frequency
Hi, @yunzhehi ,
Visitor yunzhehi
yeah,it's working, thank you.
