Observer mohammad90hgh
undeclared identifier '__UINTPTR_TYPE__'
I am trying to compile on of the xfopencv examples (histequalize) in the SDSoC for ZC702 board. I followed the steps in "Using the xfOpenCV Library on a non-reVISIONPlatform" section from here, but I get the following error:
Performing accelerator source linting for equalizeHist_accel
Performing pragma generation
INFO: [PragmaGen 83-3231] Successfully generated tcl script: /home/mhg/KnitVision/knitvision_embedded/knitvision_sdsoc/test_xfopencv_z702/Debug/_sds/vhls/equalizeHist_accel.tcl
Moving function equalizeHist_accel to Programmable Logic
ERROR: [HLS 200-70] Compilation errors found: In file included from /home/mhg/KnitVision/knitvision_embedded/knitvision_sdsoc/test_xfopencv_z702/src/xf_hist_equalize_accel.cpp:1:
In file included from /home/mhg/KnitVision/knitvision_embedded/knitvision_sdsoc/test_xfopencv_z702/src/xf_hist_equalize_accel.cpp:31:
In file included from /home/mhg/KnitVision/knitvision_embedded/knitvision_sdsoc/test_xfopencv_z702/src/xf_hist_equalize_config.h:34:
In file included from /home/mhg/tools/Xilinx/SDx/2019.1/include/hls_stream.h:33:
In file included from /home/mhg/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-none-eabi/arm-none-eabi/include/c++/8.2.0/queue:62:
/home/mhg/tools/Xilinx/SDK/2019.1/gnu/aarch32/lin/gcc-arm-none-eabi/arm-none-eabi/include/c++/8.2.0/bits/stl_function.h:418:10: error: use of undeclared identifier '__UINTPTR_TYPE__'
 return (__UINTPTR_TYPE__)__x > (__UINTPTR_TYPE__)__y;
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling '/home/mhg/tools/Xilinx/Vivado/2019.1/bin/vivado_hls /home/mhg/KnitVision/knitvision_embedded/knitvision_sdsoc/test_xfopencv_z702/Debug/_sds/vhls/equalizeHist_accel_run.tcl -l equalizeHist_accel_vivado_hls.log'
sds++ log file saved as /home/mhg/KnitVision/knitvision_embedded/knitvision_sdsoc/test_xfopencv_z702/Debug/_sds/reports/sds_xf_hist_equalize_accel.log
ERROR: [SdsCompiler 83-5004] Build failed
src/subdir.mk:21: recipe for target 'src/xf_hist_equalize_accel.o' failed
make[1]: *** [src/xf_hist_equalize_accel.o] Error 1
makefile:39: recipe for target 'all' failed
make: *** [all] Error 2
I have attached the full sds++ log file. I also tried the solution in this but it didn't work for me. Does anyone know how to fix this?
OS version: Ubuntu 18.04.3
SDx version: SDx 2019.1
Mohammad
Re: undeclared identifier '__UINTPTR_TYPE__'
Hello @mohammad90hgh
Have you set the Linux root file system environment variable $ SYSROOT?
Also, If you are using a non-revision platform then as a prerequisite it is required to install/compile OpenCV libraries(with compatible libjpeg.so)
There is a small note in UG1233 which states that,
Note: The OpenCV library is not provided by Xilinx for custom platforms. You are required to provide
the library. Use the reVISION platform in order to use the OpenCV library provided by Xilinx.
Best Regards,
Nutan
