zynq zcu102 opencl linux
After running the provided opencl example in the zcu102 I was trying to make it work in the Ubuntu desktop created by Xilinx. This ubuntu desktop can run sdsoc applications so I thought the same could be done with OpenCL.
I tried the following steps:
1) Enable the OpenCL driver in petalinux 2017.1 (zocl).
2) Added to device tree system-user.dtsi something like:
zocl_drm {
compatible = "xlnx,zocl";
status = "okay";
reg = <0x80000000 0x10000>;
3) do a petalinux-build and get image.ub and boot.bin
4) copy the so libraries from the opencl example sd_card into ubuntu desktop following the steps in init.sh.
cp /mnt/platform_desc.txt /etc/xocl.txt
cp /mnt/libxilinxopencl.so /usr/lib/libxilinxopencl.so
5) export xilinx_opencl
root@linaro-gnome:/mnt/opencl# export XILINX_OPENCL=/mnt/opencl/embedded_root/
6) try to run with
root@linaro-gnome:/mnt/opencl# ./opencl_test3.exe binary_container_1.xclbin
ERROR: No devices found
[ 147.846968] pgd = ffffffc05db53000
[ 147.852407] [00000000] *pgd=000000005c59c003Segmentation fault
I am wondering if this approach is way off or I am missing something ? Maybe the device tree fragment is incorrect ?
Re: zynq zcu102 opencl linux
for the zcu102 (note: run time hard-codes base address, so you must map to same M_AXI_GPs as the 102.
xlnk {
compatible = "xlnx,xlnk-1.0";
&amba {
zyxclmm_drm {
status = "okay";
reg = <0x0 0xA0000000 0x0 0x10000>;
for zynq:
xlnk {
&amba {
zyxclmm_drm {
status = "okay";
After enabling the opencl driver in Petalinux I cannot see any references to check if it has been loaded doing dmesg | grep zocl.
I am not sure if the source code for this driver is up-to-date in the linux kernel since there are some differences on how the functions are called and maybe it is being ignored and not compiled into the kernel.
Thank you for this issue which is useful to me. But I'm still confused about is there an ip core for zocl exist? I want to know how should I set the Vivado design project to match the added device tree. Because I can't find the 0xA0010000 address in any definition file for zocl. Should I add an AXI Interconnect in my Vivado project or any other IP core for zocl to correct this problem?  I do need a guid for how to add the zocl runtime to ZynqMP platform with linux.
