200G ILA IP core rx_meop_err simulation problems
hello,I use 200G ILA IP to sim,when input continuous two packages without eop,but the output - rx_meop_err does not pull,can someone gei we little help?thanks.
Re: 200G ILA IP core rx_meop_err simulation problems
Hello @allen_benpao,
Could you please explain in more details what is the issue you are seeing?
Please note that IP-ILA/2000G is an Intel product, not Xilinx.
Andre Guerrero
Product Applications Engineer
