7 Series FPGA TMR Options
For Virtex 5 and older FPGAs, TMRTool provides extensive TMR support.  Does Xilinx offer any tool like this for implementing TMR in 7 series FPGAs with Vivado?  The Vivado IP TMR Manager and other related components seem to be intended for just MicroBlaze.  I'm checking to see if there are other options than just using 3rd party synthesis tool TMR features.
peadard
Hi @j882xilinx384uid, unfortunately not, for newer parts than Virtex-4 and Virtex-5, you should work with your preferred synthesis third party vendor of choice, be it Synopsys Synplify Premier or Mentor Graphics - Precision Hi-Rel.
peadard
Okay, thanks for the feedback.
