programflash
Adding "ChipScope definition and connection file"
After adding "ChipScope definition and connection file".
Trying to implement this ChipScope, I get a fatal error:
A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffd70100e72, pid=38244, tid=27992
# JRE version: 6.0_21-b07
# Java VM: Java HotSpot(TM) 64-Bit Server VM (17.0-b17 mixed mode windows-amd64 )
# Problematic frame:
# C [ntdll.dll+0xa0e72]
# An error report file with more information is saved as:
# C:\SVN\ChiScope\G5\FPGA\DFR\hs_err_pid38244.log
ERROR: Chipscope Inserter (Setup Mode) launch failed. --
I run the ISE project Navigator in windows 7 compatible.
Tags (2)
