Voyager
Voyager
Analysing system monitor in chipscope(ILA)
With sysmon one can monitor temperature and voltage of FPGA. Thats clear.
There are several voltages parameters in ILA shown as in screenshot attached. I would like to know, is there any document describing which voltage is what?
I am using xcvu3p and would like to see vref(0.9v) of bank 44 and bank 47 needed for IO standard SSTL18_I_DCI. which one is vref there?
Furthermore is there any way to see if DCI also set in the bank or not?
Hi @fpgalearner,
It looks like to manage the Vref for specific banks, you need to use the System Management Wizard IP.
Please take a look at the document System Management Wizard v1.3 - PG185. On page 65, you can see the following information:
You can also find some more information about the XADC in the document UltraScale Architecture System Monitor User Guide - UG580.
Andre Guerrero
Product Applications Engineer
