BASYS2 Maximum limit
Hey folks,
I need to provide random numbers for a generic multiplier, but the inputs & outputs will be increasing for example like this:
INPUT(2 bits) - OUTPUT(4bits)
INPUT(4 bits) - OUTPUT(8bits)
INPUT(16 bits) - OUTPUT(32bits)
INPUT(32 bits) - OUTPUT(64bits)
INPUT(64 bits) - OUTPUT(128bits)
INPUT(128 bits) - OUTPUT(256bits)
and so on . .......................................
I have to test these INPUTs/OUTPUTs as longer as possible until the message "ERROR:Pack:18 - The design is too large for the given device and package." take the screen.
Please let me know if somebody knows what is the limit!, I want to know if I have to expand my LFSR  to 164 bits or more, thanks in advance . .
Tags (3)
Check the device resource guide . You must not use more than available IO in the target device .
Check board master ucf/XDC file or target device resource guide
Thanks and Regards
Balkrishan
hi
basys2 is a spartan-3e 100 cp132 package. this means that there are only 132 pins on the fpga.
you are getting the error because you are over-utilizing the IO's in the fpga.
since you are trying to implement a pseudo random number generator, you can refer the code available here as an example.
http://stackoverflow.com/questions/14497877/how-to-implement-a-pseudo-hardware-random-number-generator
--hs
