bkeitch
**BUG** in IBERT scripts
There is a bug in the scripts for IBERT testing.
I am using the board KCU116. It fails the self-test using the SCUI
When testing the SFP modules with looback device provided.
The TCL script has "LINKGROUP_0"
But this is not found using Vivado 2019.2
To get these scripts to work replace "LINKGROUP_0" with "Link_Group_0" throughout the scripts.
Also note that the DIP switch 6 on bank SW21 must be ON for JTAG mode (this is not mentioned anywhere)
Xilinx: Please fix this
anunesgu
Hi @bkeitch,
Thank you for reporting this issue.
Could you please let me know the name of the script where you had to make the modifications?
I found the reference "LINKGROUP_0" in the scripts get_ibert_gty_status.tcl and setup_ibert_gty.tcl. Are those the ones you modified?
Thank you,
Andre Guerrero
Product Applications Engineer
bkeitch
These scripts are found in the file:
rdf0409-kcu116-gty-ibert-c-2019-1.xip
bkeitch
Document Type: Example Designs
Creating and Using a GTY IBERT Design for the KCU116
