Newbie snowcrux
Can't install install_drivers
I install the cable drivers by using add design tool on Vivado 2014.4 and Windows 7 (64 bits, SP1), and the installation is succeeded.
But I can not connect a hardware (NEXYS 4 evaluation board) through open target command.
I re-open the add design tool, the "Install Cable Drivers" is not checked.
Could you tell me how I connect the hardware?
Re: Can't install install_drivers
Which cable are you using? i.e., Digilent cable or platform usb cable?
While connecting through the hw manager of Vivado, are you encountering any error message?
Also check Vivado.log for any information (Vivado GUI --> File --> Open Log File)
After connecting the board using cable, check the device manager and confirm whether the cable drivers are installed successfully?
Vinay
Please check if below answer records are helpful for which discuss about cable driver installation
http://www.xilinx.com/support/answers/54382.html
http://www.xilinx.com/support/answers/54381.html
Ashish
Refer below link:
http://forums.xilinx.com/t5/Design-Tools-Others/Vivaldo-2013-3-on-Win-7-cable-driver-installation-failed/m-p/379067/highlight/true#M5086
Anusheel
Helpful answer -> Give Kudos
Moving to correct board.
Thanks,Vijay
Hello @snowcrux ,
Did you check responses for your query?
In case the issue is resolved, feel free to close the thread by marking the post helped as solution.
Ashish
