Cannot instantiate Chipscope
Hello!
I have problem with Chipscope PLBv46 Integrated Bus Analyzer (IBA) that I cannot resolve. I want to monitor the transactions on my PLB Bus, and there I have added the IBA IP and connected it to the PLB Bus. No matter what I do and how I connect the IP, I get the same error message during synthesis:
"Multi-source in Unit <chipscope_plb_iba_0> on signal <chipscope_icon_control<3>>"
In one way or another it seems to be multiple drivers on the "chipscope_icon_control(3)" signal when the IP is instantiated, but I do not understand why. I have also tried to make these signals external, and it does not change anything at all.
I am using Xilinx Platform Studio Version 9.2.i
Anyone who know what might be wrong or who have encountered the same problem?
Best regards
Olav T.
check this ARs
http://www.xilinx.com/support/answers/38890.html
Thanks and Regards
Balkrishan
Sorry, but I am confused? How does that AR help me in my case?
No one with any clue about this?
Please show the connectivity of different bus connections of the chipscope core in your design to help.
