08-26-2016 12:17 AM - edited 08-26-2016 12:18 AM
Hello Guys,
i have a problem with debugging in Vivado. Normaly it works always, but in
the current project not. I have set like always my debug signals with "setup De Bug".
After generating the bitstream, i open the hardware manager, flash the device but i don't see any
debug signals. I receive the following message:
When i open the implemented design, i see that the debug cores are placed in the device. I Also see the
Schemetic:
The Clock for the debug cores comes from the Processing System -> FCLK_CLK0. So it should be a free-running clock.
Does anyone know what i did wrong? thanks
08-26-2016 12:25 AM - edited 08-26-2016 12:27 AM
your project may got corrupted. I think you can try with new project
https://forums.xilinx.com/t5/Design-Tools-Others/Hardware-Manager-finds-no-debug-cores/td-p/710113
check this guide as well
08-26-2016 12:30 AM
Hi @astei87,
Can you please try connecting system clock to ILA and implement the design again?
Let us know if the issue persists after connecting sys_clk.
08-26-2016 06:30 AM
Thx for you help guys,
it seems that my design was somehow corrupted. I've built a new design and it works now. Thank you
