rcinmo
Chipscope core random generation problems
14.4 ISE,  XC6VLH550T.  Numerous iterations of trying to include chipscope using the chipscope core inserter.  First I was having timing issues including the chipscope ILA, once I solved the timing problems in the HDL I would get a core when I brought up the analyzer but the signals weren't what I had included in the core inserter once I fixed the timing problem.  So I did a project clean with the same results.  Then deleted the cdc file as well as a project clean.  Now I meet timing, all signals routed, all constraints met.....but when I bring up the fpga editor it tells me no cores found.  Not seeing any warnings that would indicate a reason for no core.  At this point I'm stumped.  HELP
I've used chipscope succesfuly before but It's been at least 18 months...so I'm hoping it's something simple I forgot.
vijayak
Hi @rcinmo
Please post the full error/warning message that you are seeing.
Thanks,Vijay
rcinmo
Hi @vijayak Thats just it, other than the 0 cores found in chipscope analyzer, and no cores found in the FPGA editor I don't see anything that tells me a problem.  I did figure one thing out, I had to shorten the path and path file names and was able to get a core in according to the fpga editor...but CS analyzer still says no cores.
rcinmo
Now I'm back t the same issue, the ILA info for nets is old, not the current core. Thanks
rcinmo
Disregard the path fix.  With no change to the HDL, ucf or source files.  Sometimes I get CS core in FPGA editor sometimes I don't. If I get a core in the FPGA editor, I may or may not get a core in analyzer.  If I get a core in analyzer the signal definitions are wrong.  It's like there is a file pointer looking at the wrong file.
rcinmo
Finally got the analyzer to load.  Results of the process are random wether it includes a core or not.  I have no idea what is going on.
