Chipscope in ise 14.7 - ERROR:TSDatabase:19
I have a project which works fine until I try to use Chipscope.
During mapping, I get errors:
ERROR:TSDatabase:19 - Processing TIMESPEC definition
TS_D2_TO_T2=FROM:D2_CLK:TO:FFS:TIG:
No TNM, TPSYNC or user group named "D2_CLK" is defined.
TS_J2_TO_D2=FROM:FFS:TO:D2_CLK:TIG:
TS_J3_TO_D2=FROM:FFS:TO:D2_CLK:TIG:
TS_J4_TO_D2=FROM:FFS:TO:D2_CLK:TIG:
INTERNAL_ERROR:Pack:pkibangm.c:2584:1.87 - 4 timespec errors found
I managed to find this which has the exact errors:
https://www.xilinx.com/support/answers/43548.html
But, the solution didn't work, the alternative workaround means nothing to me so I currently don't know how to try that.
Can anyone help?
Re: Chipscope in ise 14.7 - ERROR:TSDatabase:19
This post has detail on the alternative solution which is setting an environment variable:
https://forums.xilinx.com/t5/Design-Tools-Others/ChipScope-Clock-Problems/m-p/428900?device-view=desktop
Ah, thank-you!
It would have been useful if the AR# actually stated it was a system/environment variable and not something that goes into one of the project files somewhere....
