wojtq
Chipscope pro startup trigger mode support
i'm trying to use Chipscope pro 13.2 to run my project under Virtex-5 in startup trigger mode. Is this true that this mode is supported from Virtex-6 and Spartan-6 and later FPGAs or I'm doing something wrong? Maybe later ISE Design Suite can help me?
In command line I have info:
opening design database (*.ngd file)
opened (ngd)
error creating .....\file.ctj
and error: virtex5 is an unsupported architecture. Only Virtex6, Spartan6, and later FPGA devices are supported by this tool
When I'm creating ctj file by Trigger Setup -> Save Trigger Setup all is ok
this error occurs only when I use Trigger Setup -> Save Startup Trigger Files
Maybe my ngd file is broken? Whole project passed synthesis, implementation and programming file generation.
hj
This feature is only supported in Virtex-6, Spartan-6 and the newer products in the 7 Series families.
Since you are using virtex 5 tool is throwing error.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
hj
sampatd
Yes it is supported for 6 series and above. Check the following AR:
http://www.xilinx.com/support/answers/41565.htm
