hrmt
Chipscope
What is the difference between Trigger condition  with capture condition ?
can any answer with a simple example ?
what happen if both of them is equal?
hongh
Hi, @hrmt ,
If the trigger position is larger than 0, the ILA core will capture pre-trigger data into its data capture window.
Once the pre-trigger data has been captured, the ILA core will transition to the Waiting for Trigger status.
hongh
Hi, @hrmt ,
Are you using ILA in Vivado?
hrmt
Hi @hongh
Yes in ILA there is two type of condition: Trigger and Capture.
hongh
Trigger  condition:     Decide in which condition, the ILA will be triggered.
Capture condition:     When the ILA core status is Pre-Trigger, Waiting for Trigger, or Post-Trigger, decide the condition that which data will be shown for you.
hrmt
but in ila core state we have pre-trigger state. what this mean?
hongh
Hi, @hrmt ,
hrmt
You mean that if, for example trigger position is 10 and window data depth is 16:
10  first data do not need to happen trigger condition for capturing and only capture condition should be happen for this 10 first data?
hongh
Hi, @hrmt ,
Only when ILA core is triggered, tool will try to capture the data(equal condition) in the captured data(pre-trigger, triggered, post-trigger)
hrmt
Hi @hongh
first, thanks for your attention to my question.
yes when trigger condition and capture condition is equal tool show data only when triggered.
but now my question is that : when trigger condition and capture condition is different and trigger position is i.e. 10, now for first 10 position in ila window only capture condition should be happened?
hongh
No matter when trigger condition and capture condition is equal or not equal, tool show data only when ila core is triggered.
When trigger condition and capture condition is different and trigger position is i.e. 10, the data equal capture condition in position(0~ 10) will also be captured (with the yellow line in the above pic)
hrmt
is this the correct image?
hongh
I think it's correct.
The captured data can be in any position from 0 to n.
hrmt
thank you for your attention...
