Voyager
Voyager
Control VIO from bare metal application
Is there a way to control VIO (set output ports, or even retrieve values) using a bare metal application? I was thinking of adding a specific AXI peripheral but there might a better solution than this that I don't know.
Thanks!
Sébastien.
--Sebastien
Hi @sebo,
The VIO is controlled from the HW Manager GUI in Vivado or via TCL commands (also from withing Vivado). There isn't a way to control it from the SDK or from the PS side in a Zynq.
Andre Guerrero
Product Applications Engineer
Hi @sebo,
Andre Guerrero
