Debug Error "[Labtools 27-3428] Ila core [hw_ila_0] clock has stopped. Unable to arm ILA core."
I have added an vivado's "Integrated Logic Analyzer" in my block design. My block design is contained of many other sub-blocks. I placed the ILA in one of the sub-blocks to debug the internal signals. After creating hardware wrapper, synthesizing, implementation and Bitstream generation, i programmed the Artix 7 FPGA.
My debug core is available with all probes, but when i press "Trigger" to view signals, i face the following error.
Please guide me where is the issue.
The debug ila core was automatically instantiated by Vivado.
Thank you in Advance!
Hi @naeemahmad,
Could you please share the model of the device that you are using?
In addition, could you try to open up the Elaborated Design or Synthesized block diagram and verify which clock is connected to the ILA? Is it the same clock being used for the rest of the logic? (share a screenshot if possible).
You can also try to insert the ILA after the Synthesis, using the Set Up Debug Wizard (but the way you did should work as well).
Andre Guerrero
Product Applications Engineer
Hi @naeemahmad,
Andre Guerrero
Hello @anunesgu,
Thanks a lot. It was problem with my hardware. It was not generating clock input for the ILA.
I rechecked and now it is working.
Kind regards
Naeem
