cosmin_iorga
Developer feature in Vivado for adding custom functions
Does anyone know if there is a developer feature in Vivado to add custom functions or scripts? I have looked at the Xilinx Alliance Program but I could not figure out if I can do this or not. I want to add this feature: when FPGA designers finish their design and generate the bitstream configuration file they would have an option in Vivado (click of a button or checkbox) to automatically generate also a “matching” Vector Network Analyzer (VNA) IP as a second bitstream configuration file for power integrity analysis (VNA probing ports are connected to the on-die power supplies and the VNA measures the PDN impedance profile and S-parameter model of the PDN).  The VNA can be used to test the hardware before debugging the real design.  The VNA IP is automatically customized for their design (the I/O pins configuration and pin assignment, input clock pin and clock frequency... all this info would be transferred automatically from their project into the VNA IP configurator). Has anyone added custom functions to Vivado? Is this possible?
Cosmin
anunesgu
Hi @cosmin_iorga,
In Vivado, under Tools -> Xilinx Tcl Store, you can see a set of functions and libraries that are 3rd party created and supported.
ultimately, all these 3rd party libraries are store in the following Xilinx Github link: https://github.com/Xilinx/XilinxTclStore/wiki/Support
You can request submit your script and request it to be published there.
Thanks for contributing!
Andre Guerrero
Product Applications Engineer
hbucher
@cosmin_iorga There are places to customize post script execution but that has to be done in a per project basis.
If you run vivado in TCL mode you can automate that. With the benefit of continuous integration.
cosmin_iorga
Thank you hbucher for the suggestions.  I am trying a different format than customizing per project basis in TCL mode.  I am trying to make this power integrity tool available to all Xilinx customers directly through Vivado same as IBERT is available for signal integrity analysis.  Can anyone point me in any direction how to approach this task?
anunesgu
Hi @cosmin_iorga,
Andre Guerrero
