Newbie jsvickers
Device Checksum is Impact Version dependent?
Had a slight manufacturing issue today.  We program FPGAs with an MCS file, using Impact, but manufacturing threw an unhandled exception today because they don't get the right checksum any longer when programming devices with a newer version of xilinx tools.
Details:
Using xilinx 13.2, we program an FPGA with and MCS file.  After completing successfully, we ask for a checksum, and we get a number back -- CHECKSUM1
Then manufacturing updated their software to version 14.6.
Using xilinx 14.6, if we program the same exact FPGA with the exact same MCS file, it also completes successfully.  But when we ask for a checksum we get a different number -- CHECKSUM2
Concerned that we might not be programming with the same MCS file, I reinstalled version 13.2 and asked for the checksum, then got the original number back (CHECKSUM1).
By my way of thinking a checksum should not be xilinx version dependent.  Can you confirm this behavior?
Jim.
Re: Device Checksum is Impact Version dependent?
I do not think checksum will change with tools version. The below is procedure to obtain checksum from mcs file. Verify once.
You can find the 32-bit checksum from the .prm file generated together with the .mcs file using PROMGen. If the .prm file is unavailable, you can run the following command to re-generate the .prm file where you can find the 32-bit checksum.
promgen -w -c 00 -r <input .mcs file name>.mcs -o <output .mcs file name>.mcs
You should use the following command if you want to get the checksum, including the pre-filled value for a PROM with specified density. The default pre-filled value is FF.
promgen -w -c <pre-filled value in hex> -r <input .mcs file name>.mcs -o <output .mcs file name>.mcs -s <number in KB>
If you want to get an 8-bit per line checksum in a .mcs file, you can refer to (Xilinx Answer 18884).
