Do constraints need to be defined for debugging after using system ILAs?
Hi everyone,
I am using Vivado 2018.2 for my current project. I am relatively new to this environment and I am trying to mark certain connections as debug. the automation wizard pops up and inserts system ILAs once I do that. I have assigned the clock and adjusted the probe widths for the ILAs that are being used. However I am very new to using ILAs.
The question might sound weird but I would like to know if I have to still include constraints related to debug probes and nets when I have system ILAs to do the task.
Can someone suggest if what I implied makes sense? If not, can someone suggest how do I proceed?
Thanks in advance,
-Chandrasekhar DVS
dpaul24
@krishnachandrasekhar100 ,
No, as an user you do not need to set constraints for ILAs, the cores come with their own constraints. Think of them like tap-outs inside the design and so do not affect your data. However they affect design placement and consequently routing of signals.
To know about the core read this - https://www.xilinx.com/support/documentation/ip_documentation/ila/v6_2/pg172-ila.pdf
To get an idea how to use read this - https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug936-vivado-tutorial-programming-debugging.pdf
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
dpaul24
Thanks for the clarification @dpaul24 !
Also there are 'system ILA' and 'ILA(Integrated Logic Analyzer)' IPs in the IP catalog. I saw in some videos that the configuration mechanism is same for both the IPs. Apart from that, are there any other notable differences between them?
-Chandrasekhar DVS
Tags (2)
