Newbie ajfengr
ERROR:Bitstream:25 - 0xd5ae bytes loaded up from 0x0 would exceed promsize 0x8000.
I'm using iMPACT version 14.2 (P28.xd).  I'm programming a Spartan-3AN device, xc3s50an.  The datasheet indicates this device has 1M bits of Flash, of which 437,312 are available for device configuration.  Here's what I get when I try to run iMPACT:
Override chain at index 0.
Overriding chain at index 0.
   Sector_Addr  Page_Addr   PO2_Addr   Non-Binary_Addr
1 128 32768 65536
2 256 65536 131072
3 384 98304 196608
'1': Loading file 'C:/xilinx/trace_cpld/trace_cpld.bit' ...
INFO:iMPACT - Elapsed time =      0 sec.
done.
INFO:iMPACT:501 - '1': Added Device xc3s50an successfully.
file : C:/xilinx/trace_cpld/trace_cpld.bit  used size : 437312
Add one device.Next Start Address=d593
INFO:iMPACT - Current time: 9/3/2013 3:13:39 PM
Total configuration bit size = 437312  bits.
Total configuration byte size = 54664 bytes.
     Why is iMPACT failing?  We found an older version of iMPACT (11.1) in a standalone package.  And it seems to work fine.  What's wrong with this version now?  Another odd symptom is when I add the FPGA device to iMPACT, the tool indicates it has 131,072 bits available.  But that's wrong, it should be 1M bits.
     Thanks!
Re: ERROR:Bitstream:25 - 0xd5ae bytes loaded up from 0x0 would exceed promsize 0x8000.
It is the issue with Impact 14.2.
To work around this issue Roll back to a previous version of the software.
This issue will be resolved in a future release of software.
