ERROR:iMPACT:583 - '1': The idcode read from the device does not match on Xilinx Parallel Cable IV
HI! I have a problem when i am using Xilinx Parallel Cable IV to do the programming on my CPLD. Error msg :
INFO:iMPACT:1777 -
   Reading C:/Xilinx92i/xbr/data/xc2c64a.bsd...
INFO:iMPACT:501 - '1': Added Device xc2c64a successfully.
Bit count is 25812.
ERROR:iMPACT:583 - '1': The idcode read from the device does not match the
   idcode in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00001111111111111000111111111111
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000110111001011000000010010011
Elapsed time =      0 sec.
But, i do not have this problem when i am using Parallel cable came with the development board (XC2-XL from digilent).
Any idea?
Alex
Anonymous
Not applicable
  • In most cases, this IDCODE error message is indicative of a board problem. Mostly problems related to JTAG chain hardware. So please check all the programming hardware of your board.
  • Perform an IDCODE looping test. If IDCODE looping fails, see http://www.xilinx.com/support/answers/8902.htm
  • Check all the connections as per configuration guide recommendations
  • Check the continuity of the cable & cable insertion direction.
  • Check all the voltages of FPGA. They should be with the range  as per data sheet recommendations
