11-12-2014 05:03 AM
Hi everybody,
I've been trying to run Fail-Safe Design in Spartan-6 Family tutorial on ISE 13.4. Everything was done without any problems.
Isolation verification tool doesn't notify any violations, when I run the chek against UCF. But by running a check against the netlist, I became so much violations related to Tile summary. Hier is the extract of the report:
Tile Adjacency
Net Adjacency Violations: 60
Logic Adjacency Violations: 0
Tile Content
Net Content Violations: 7
Logic Content Violations: 15
Inter-region Signals
Inter-region Net PIP Violations: 79
Inter-region Load Violations: 0
I attach also SVG files of UCF and netlist check.
Do you have any idea, what can be wrong in my design?
Best regards,
Emil Gracic
11-12-2014 10:48 AM
Check that your regions have the proper spacing (distance) for each other,
There must be unused logic and routing sufficiently wide between regions so there is no possibility of a defect or failure creating a connection.
11-13-2014 01:37 AM
Thanks for reply,
as said, I followed the instructions from tutorial, and everything was done identical as in tutorial. Only the version of Xilinx ISE is not the same: In tutorial will be used 12.4 and I've been using 13.4...
Best regards,
Emil Gracic
