04-09-2013 04:07 AM
i'm using xpa to estimate the dynamic power of my design.. when doing the simulation, xpa computes acceptable static and dynamic power values. The problem is, when i want to estimate these values using the only ncd file (place and route report of my design), the dynamic power is equal to zero..This seems to be obvious since the frequency taken as input is equal to zero. Actually, i want to ask, how the XPA calculates the input frequency? and why it is equal to zero? and my final question is: can i set manually the frequency in the input so that the dynamic power will be more realistic?
Thank you in advance
04-09-2013 05:48 AM
XPA does not try to calculate the frequency. You must enter it manually if you don't
provide simulation data. You can manually enter the clock frequencies in the
tables under Details --> By Clock Domain. You might also want to change the
default activity rates under Project Settings.
04-09-2013 11:20 AM
I tested Xilinx's example « S6_tutorial_top_16bit » without simulation data.I have just used ncd file. I didn't fix manually clk values and XPA estimates power correctly. In power report, I found that the input frequency were fixed at :
| Logic:
| pll_in_bufg_inst = 33.00 MHz
| Nets:
| clk33_pll = 32.87 MHz
| pll_in = 33.00 MHz
| CLK33_IBUF = 33.00 MHz
| pll_clkfb = 32.87 MHz
| Logic:
| SP6_BUFIO_INSERT_ML_BUFIO2_0 = 200.00 MHz
| SP6_INS_BUFIO2FB_DCM_ML_BUFIO2FB_1 = 199.87 MHz
| dcm_feedback_bufg_inst = 199.87 MHz
| dcm_clk_bufg_inst = 159.90 MHz
| Nets:
| clk = 159.90 MHz
| dcm_fbout = 199.87 MHz
| dcm_clk = 159.90 MHz
| DCM_SP_inst_ML_NEW_DIVCLK = 200.00 MHz
| DCM_SP_inst_ML_NEW_O = 199.87 MHz
| dcm_fbin = 199.87 MHz
| clk_ibufgds = 200.00 MHz
so, my questions are :
In this example, how these clk's values were fixed ?? From where XPA extracted these values ?
thank you in advance
04-09-2013 12:06 PM
It's possible that the values came from constraints. It's not clear how the constraints ended
up in the ncd file. Perhaps it depends on how the constraints were defined (ucf vs HDL source, etc.).
04-16-2013 04:00 AM
i just have a question about combinational circuits: how to calculate the dynamic power for circuit which doesn't contain a clock with the XPA tool?
04-16-2013 06:12 AM
First I'd like to give a better answer to your previous question:
Loading a design I got the following warning:
WARNING:Power:1369 - Clock frequency for one or more clocks was not found through
timing constraints (PCF file) or simulation data.
This indicates that it is the physical constraints and not the user constraints used to
determine clock frequency. In my case it was warning me about DQS signals which
MIG uses as clocks, but don't have a period constraint. If for some reason your
period constraints did not propagate to the PCF file, then you could get this warning
when you start XPA.
If you look under Details --> By resource type --> IOs
You will get a table of all your inputs and outputs. You can edit the signal rate and duty cycle (% high)
for each pin to estimate the actual dynamic power. Of course it would be more accurate to provide
simulation data, instead.
