fdpousa
Generating eye diagram using zynq-7000 (ZedBoard)
Hi all,
I want to generate an eye diagram using a ZedBoard. The main idea is debug a signal and generate an eye diagram using IBERT IP Core. When I tried to do add IBERT a message says "IP is disabled because it does not support the current part", in compatible families I can see that the part place on ZedBoard is not included.
Do I have any other alternative using a Zedboard and monitoring the eye diagram with Vivado?
Tags (4)
klasha
The Zedboard uses a Zynq xc7z020. This part doesn't include any kind of MGT. IBERT is only usable with MGTs (GTP, GTH, ...).
For the selectio-pins, the part only has HR-Pins. These are in optimal conditions able to drive a 1.2GBit/s Signal.
As far as I know, there's no internal way to do a proper eye scan on selectio-pins. I would use a good oscilloscope and measure with that.
klasha
anunesgu
Hi @fdpousa,
@klasha is correct! The part included in the ZedBoard does not have any GT transceiver, therefore, you cannot use the IBERT IP to monitor and generate eye scans.
Since you are using the SelectIO ports to transmit data, the only option is to use an oscilloscope to directly measure it.
Andre Guerrero
Product Applications Engineer
