alessandro91
Hardware Manager finds no debug cores
I'm working on a Zybo board by Digilent and I want to use the only FPGA part of the zynq7000.
I instantiate ILA (set up the debug after the synthesis), selecting some signals and using only clocks generated from a MMCM starting from the free running clock on the pin L16 (I also tried to use the clock after the IBUF followed by BUFG).
I succeed in generating the bitstream, but when I open target in the hardware manager the message "There are no debug cores" appears and I cannot use ILA to debug my system.
When I run 'report_debug_core' in the Tcl console I get the following output:
Copyright 1986-2016 Xilinx, Inc. All Rights Reserved.
| Tool Version : Vivado v.2016.2 (lin64) Build 1577090 Thu Jun 2 16:32:35 MDT 2016
| Date : Mon Jul 18 16:29:20 2016
| Host : archimede17 running 64-bit Fedora release 15 (Lovelock)
| Design : Main
| Device : xc7z010clg400-1
| Speed File : -1
Debug Core Information
Table of Contents
1. Debug Cores
1.1 dbg_hub: (labtools_xsdbm_v1, black box, inserted)
1.2 u_ila_0: (labtools_ila_v6, black box, inserted)
1.3 u_ila_1: (labtools_ila_v6, black box, inserted)
1. Debug Cores
Parameter Data for Debug Core "dbg_hub"
| Parameter | Value |
| C_CLK_INPUT_FREQ_HZ | 300000000 |
| C_ENABLE_CLK_DIVIDER | false |
| C_USER_SCAN_CHAIN | 1 |
Channel Data for Debug Core "dbg_hub"
| Port Name | Port | Port Spec | Channel Name | Net Type | MARK_DEBUG | Net Name |
| | Type | | | | | |
| clk | input | clk | clk[0] | signal | false | CLK_IN1 |
Peripherals Connected to Debug Hub 'dbg_hub' (2 Peripherals):
| Index | Type | Instance Name |
| 0 | ila_v6_1 | u_ila_0 |
| 1 | ila_v6_1 | u_ila_1 |
Parameter Data for Debug Core "u_ila_0"
| Parameter | Value |
| ALL_PROBE_SAME_MU | true |
| ALL_PROBE_SAME_MU_CNT | 4 |
| C_ADV_TRIGGER | true |
| C_DATA_DEPTH | 1024 |
| C_EN_STRG_QUAL | true |
| C_INPUT_PIPE_STAGES | 0 |
| C_TRIGIN_EN | false |
| C_TRIGOUT_EN | false |
Channel Data for Debug Core "u_ila_0"
| Port Name | Port | Port Spec | Parameters | Channel Name | Net Type | MARK_DEBUG | Net Name |
| | Type | | | | | | |
| clk | input | clk | | clk[0] | signal | false | clk_sonda |
| probe0 | input | probe | PROBE_TYPE=DATA_AND_TRIGGER | probe0[0] | signal | false | frame1 |
Parameter Data for Debug Core "u_ila_1"
| Parameter | Value |
Channel Data for Debug Core "u_ila_1"
| | Type | | | | | | |
| clk | input | clk | | clk[0] | signal | false | CLK_IN1 |
| probe0 | input | probe | PROBE_TYPE=DATA_AND_TRIGGER | probe0[0] | signal | false | gate |
report_debug_core: Time (s): cpu = 00:00:00.02 ; elapsed = 00:00:00.08 . Memory (MB): peak = 7516.145 ; gain = 0.000 ; free physical = 2804 ; free virtual = 22315
Am I making any mistake? I really don't know how to proceed
PS: I attach the constraint file .xdc
alessandro91
Thank you for your quick answer.
I tried what you suggested, but I couldn't solve the problem. Then I generated a new project, identical to the previous one and I introduced a VIO that takes the same inputs of the ILA core. Now everything is working.
ashishd
Hello @alessandro91,
Can you follow below suggestions and update the results -
1. After configuring the device, right click and select 'Refresh Device'. This re-scans the FPGA device and refreshes the Hardware window.
2. If you still do not see the ILA core after programming and/or refreshing the FPGA device, cross-verify that device was programmed with the appropriate .bit file
3. Make sure that implemented design contains an ILA core. Also, check to make sure the appropriate .ltx probes file that matches the .bit file is associated with the device.
Ashish
arpansur
Hi @alessandro91,
Can you please check if the clock of the dbg_hub is connected after BUFG or not?
Also tie the reset signal of MMCM to 0 if not connected.
Arpan
alessandro91
arpansur
Hi @alessandro91,
Glad to know your issue got resolved.
Did you see any difference in schematics of passing and failing design?
Please close this thread by marking your answer as "Accept as solution".
Arpan
saunak28
What is VIO?
How you have solved the problem kindly explain in briefly
