How To Use VIO And Chipscope Core Inserter Simultaneously ?
I'm using ISE14.7 and I want to use VIO in my design. I find that  a VIO only can be included as an IP core with a ICON IP core, but I also want to use ILA cores. If I implement ILA using CORE GENERATOR, it will be a much difficult job because there are many signals that I need in different levels and components in my design, but it will be easier when I use Chipscope Core Inserter. I tried to use VIO and Chipscope Core Inserter simultaneously, but I failed. I can only find a VIO or a ILA in the Chipscope Pro Analyser without another one. Is there some simple way to use VIO and ILA in my situation?
Thanks very much!
check this document with easy steps
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/chipscope_pro_sw_cores_ug029.pdf
http://www-inst.eecs.berkeley.edu/~cs150/fa13/resources/ChipScope.pdf
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
