Observer lhbhp
How can I set tri-state for signals when I package an IP in VIVADO 2015.2?
Hi guys,
 I package an IP, which has some I/O signals. They should be tri-state inout type.
 In the IP design I set it as "I","O" and "T".When I do this in ISE, I can modify the *.mpd to make it be one I/O pin. So how can I do this in VIVADO 2015.2 ?
 Can you help me ?
Thanks a lot,
Lew
Scholar trenz-al
Re: How can I set tri-state for signals when I package an IP in VIVADO 2015.2?
set GPIO bus assign _O _T _I then it looks like 1 wire in IPI BD and vivado builds the io buffer for you
Observer lhbhp
Hi @trenz-al,
 So you mean I should do "set GPIO bus assign _O _T _I " in verilog code or in I/O planning ?
Thanks a lot,
Lew
Observer lhbhp
Hi @trenz-al,
 I find AXI GPIO IP core, should I use this? But can I use inout without AXI bus ?
Lew
regarding your first query,
You can use interface definition editor
Because a device does not have true tristate lines inside the fabric, a triple of signals (in, out, tristate) represents a tristate pair (in, out, tristate).
You can refer to following UG1118 page#78
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug1118-vivado-creating-packaging-custom-ip.pdf
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Observer lhbhp
Hi @aher,
 Thanks for your suggestion. I will try it.
Lew
Observer lhbhp
Hi @aher,
 I just see some description , but I really don't know how to put these three signals in a tristate...
Lew
Scholar trenz-al
you use GPIO interface
when ever _T is HIGH the generated IO pin is in tristate
