dreaguns
How does/can VCCINT use more current that the allowed max current per pins?
I am using the XCZU4CG Zynq Ultrascale
UG583 (Ultrascale PCB Design) says that the absolute max current via pins is 20mA
The ultrascale only has 30 VCCINT pins
If (30 * 0.020 = 600mA) but XPE Power Estimator say that VCCINT requires more current (approx. 4Amps) then,
How is the rest of the current going into the VCCINT domain or pins if they already met absolute max current?
barriet
For more information, see
https://www.xilinx.com/support/documentation/user_guides/ug583-ultrascale-pcb-design.pdf
e.g. page 49 -  "maximum possible Vccint current"
You'll notice that it depends on both the die device (e.g. ZU4) and package since both of those are possible limitations here.
barriet
The spec you referenced is how much current can be sourced or sinked from/to a SelectIO - on the outside I/O structure.
Which is a very different case than power (e.g. Vccint) or ground connection to the die on the package & substrate carrier itself.
barriet
joancab
Advisor
Advisor
I/O pins --> 20 mA
Supply pins --> much more
dreaguns
You mean to tell me that the 30 VCCINT pins on my Ultrascale can handle 52A ?
So that means 52A / 30 pins = 1.73 Amps per pin... sounds reasonable - thanks.
barriet
"You mean to tell me that the 30 VCCINT pins on my Ultrascale can handle 52A ?"
Yes - from a package & die perspective for this particular case (device & package)
That said, good luck dissipating ~44W (52A @ 0.85V - more if you consider I/O power, etc.) and being able to keep the junction temperature below max without a very impressive thermal solution.
