How instantiate IBERT with ILA/VIO in Vivado
When i try to generate a bitstream for Artix7 with Vivado 2015.3 that includes IBERT and VIO/ILA, i have this error :
ERROR: [Place 30-433] Unplaced instances found. If the tcl command place_design -verbose is used, all unplaced instances will be shown below. Otherwise, only 1 example instance will be shown.
Unplaced instance: u_ibert_core/inst/bscan_inst/SERIES7_BSCAN.bscan_inst of type BSCANE2
I open the post synthesized checkpoint and i tried to change the JTAG_CHAIN for the IBERT to 2 (JTAG_CHAIN for dbg_hub is set to 1 by default) and the bitstream is generated after i completed the place and route design
The problem is when i load the bitstream, i cannot see the IBERT window and the serials links. Only ILA/VIO are presents.
Re: How instantiate IBERT with ILA/VIO in Vivado
The problem is resolved when I apply this property for the debug_hub after synth_design.
set_property C_USER_SCAN_CHAIN 3 [get_debug_cores dbg_hub]
For IBERT core we cannot change this property so we have to change the debug_cores property.
Thanks for your help.
Hi @opal-rt_fpga_grp,
The HW Manager is configured to automatically detect debug cores in User Scan Chains 1 or 3.
Since you have assigned Chain 2 for IBERT, it will not be show automatically.
You can test is the IBERT core has been implemented and working correctly by manually launching the HW Server with the following command in TCL:
hw_server -e "set xsdb-user-bscan  <C_USER_SCAN_CHAIN scan_chain_number>"
You could also try to modify the IBERT Scan Chain to 3 to see if it gets automatically displayed along with the ILA/VIO.
Please let us know if that helps you.
Thanks!
Andre Guerrero
Product Applications Engineer
Thanks for your reply,
I have already done the test with :
set_property JTAG_CHAIN 3 [get_cells u_ibert_core/inst/bscan_inst/SERIES7_BSCAN.bscan_inst]
But when I try to load the bitstream, I have this error :
ERROR: [Labtools 27-1815] Could not find slave type in data file
I also launched in Vivado : hw_server -e "set xsdb-user-bscan 2" but it's running for indefinitely
It's normal that Vivado stays running indefinitely because that instance is busy running the HW Server in the custom mode you selected (to avoid that, you'd need to start the HW Server directly from the OS shell).
But just to test, you can leave that Vivado instance running in the background and open a new one, where you will open the HW Manager and try to perform the connection.
You can use the same command you have used, hw_server -e "set xsdb-user-bscan 2" or you can actually provide all the 4 scan chains at the same time, hw_server -e "set xsdb-user-bscan 1,2,3,4"
Andre Guerrero
response:
From the OS shell when I execute : hw_server -e "set xsdb-user-bscan 1,2,3,4"
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:MTL-D-03373:3121
_
I execute then this command : hw_server -s TCP:MTL-D-03373:3121 -e "set xsdb-user-bscan 1,2,3,4"
Same result.
response:
WARNING: [Common 17-259] Unknown Tcl command 'hw_server -e set xsdb-user-bscan 1,2,3,4' sending command to the OS shell for execution.
****** Xilinx hw_server v2015.3
  **** Build date : Sep 28 2015-20:29:55
    ** Copyright 1986-1999, 2001-2015 Xilinx, Inc. All Rights Reserved.
Cannot create TCF server: Socket bind error. Only one usage of each socket address (protocol/network address/port) is normally permitted
In Vivado 2017.1, In Hardware Device properties, we can edit the XSDB_USER_BSCAN (by default is 1,3), when I edited to 1,2,3,4 I obtain this error too :
ERROR: [Labtools 27-1815] Could not find slave type in data file.
