robertwilliam
How to add chipScope to "Spartan-6 FPGA Embedded Kit "
I check the content of "Spartan-6 FPGA Embedded Kit" on line. I do not see that it includes "ChipScope Pro Serial IO Toolkit IBERT Transceiver Test Design".
Spartan®-6 FPGA Connectivity Kit does have this function, but the upgrade package for "Spartan-6 FPGA Embedded Kit" still does not have that function. What is the reason makes Spartan-6 EDK not support ChipScope Pro Serial IO Toolkit IBERT?
"ChipScope Pro Serial IO Toolkit IBERT Transceiver Test Design" is not a simple ChipScope Pro?
wuher
http://www.xilinx.com/tools/cspro.htm
As you can see CS Pro Serial IO Toolkit is not the same as CS. Because of Connectivity Kit purpose (testing high-speed IO links) it makes sense to have Serial IO Toolkit there, and reference designs for it. Embedded Kit has a completely different purpose, therefore it does not come with Serial IO Toolkit.
robertwilliam
Thanks for your reply.
On the general ChipScope Pro (EDK should have), what cable is for it? The following JTAG download/debug cable works with ChipScope Pro?
Two USB cables – for JTAG download/debug and UART communication
