How to handle the interrupt signal of an IP when integrating with Zynq (Vivado)
I am using Vivado to start a block level design with Zynq, and 16550 UART.  Finally, I will use PetaLinux, so I assume Linux can handle the interrupt from uart.
The IP core has an interrupt pin so I am wondering where to connect this interrupt pin to?  After I did the auto connection, the AXI bus signals were connected, but not this ip2intc_irpt.
Another question is, if I have 10 such uarts, how to connect the interrupt?  I would like to start with just one, but finally I may need 10.
hi,
to integrate a IP with an interrupt, please refer to the following link. https://forums.xilinx.com/xlnx/attachments/xlnx/EDK/32012/1/AR60837.pdf
if you have multiple interrupts from different UART's, you can use the concat block.
http://www.xilinx.com/support/answers/58942.html
--hs
hi,
--hs
Thank you and it should be marked as answered however i don't know how to do it.
