01-05-2010 04:09 AM - edited 04-09-2011 09:41 AM
i want to update BRAM without re-implement. to use data2mem, i need make .bmm file
at first i make .bmm to use Command: data2mem -mf p MYPPC PPC405 0 a ROM b 0x00000000 32 s RAMB16 0x8000 2 bank -o p auto.bmm
then i imp. without -bm and use xdl command line ( planahead, fpga editor etc.) to find instance of BRAM.
and modify auto.bmm :
// Processor 'MYPPC', ID 0, memory map.
ADDRESS_MAP MYPPC PPC405 0
// Processor 'MYPPC' address space 'ROM' 0x00000000:0x00007FFF (32 KBytes).
ADDRESS_SPACE ROM RAMB16 [0x00000000:0x00007FFF]
BUS_BLOCK
bank[0].BRAM [31:30];
bank[1].BRAM [29:28];
bank[2].BRAM [27:26];
bank[3].BRAM [25:24];
bank[4].BRAM [23:22];
bank[5].BRAM [21:20];
bank[6].BRAM [19:18];
bank[7].BRAM [17:16];
bank[8].BRAM [15:14];
bank[9].BRAM [13:12];
bank[10].BRAM [11:10];
bank[11].BRAM [9:8];
bank[12].BRAM [7:6];
bank[13].BRAM [5:4];
bank[14].BRAM [3:2];
bank[15].BRAM [1:0];
END_BUS_BLOCK;
END_ADDRESS_SPACE;
END_ADDRESS_MAP;
now i re-imp with -bm auto.bmm, i get error :
Processing BMM file ...
ERROR:NgdBuild:989 - Failed to process BMM information auto.bmm
and my top level vhdl source
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
library UNISIM;
use UNISIM.VComponents.all;
entity Memory is
port (
CLK : in std_logic;
ROM_WE : in std_logic;
ROM_EN : in std_logic;
ROM_ADDR : in std_logic_vector(12 downto 0);
ROM_DIN : in std_logic_vector(31 downto 0);
ROM_DOUT : out std_logic_vector(31 downto 0);
RAM_WE : in std_logic;
RAM_EN : in std_logic;
RAM_BE : in std_logic_vector(3 downto 0);
RAM_ADDR : in std_logic_vector(12 downto 0);
RAM_DIN : in std_logic_vector(31 downto 0);
RAM_DOUT : out std_logic_vector(31 downto 0)
end Memory;
architecture Behavioral of Memory is
signal WEB : std_logic_vector(3 downto 0);
begin
WEB(0) <= RAM_WE and RAM_BE(0);
WEB(1) <= RAM_WE and RAM_BE(1);
WEB(2) <= RAM_WE and RAM_BE(2);
WEB(3) <= RAM_WE and RAM_BE(3);
BANK : for i in 0 to 15 generate
begin
BRAM : RAMB16_S2_S2
generic map (
INIT_A => X"0", -- Value of output RAM registers on Port A at startup
INIT_B => X"0", -- Value of output RAM registers on Port B at startup
SRVAL_A => X"0", -- Port A ouput value upon SSR assertion
SRVAL_B => X"0", -- Port B ouput value upon SSR assertion
WRITE_MODE_A => "READ_FIRST", -- WRITE_FIRST, READ_FIRST or NO_CHANGE
WRITE_MODE_B => "READ_FIRST", -- WRITE_FIRST, READ_FIRST or NO_CHANGE
SIM_COLLISION_CHECK => "ALL", -- "NONE", "WARNING", "GENERATE_X_ONLY", "ALL"
-- The following INIT_xx declarations specify the initial contents of the RAM
-- Address 0 to 2047
INIT_00 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_01 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_02 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_03 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_04 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_05 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_06 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_07 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_08 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_09 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_0A => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_0B => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_0C => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_0D => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_0E => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_0F => X"0000000000000000000000000000000000000000000000000000000000000000",
-- Address 2048 to 4095
INIT_10 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_11 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_12 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_13 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_14 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_15 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_16 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_17 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_18 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_19 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_1A => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_1B => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_1C => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_1D => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_1E => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_1F => X"0000000000000000000000000000000000000000000000000000000000000000",
-- Address 4096 to 6143
INIT_20 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_21 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_22 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_23 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_24 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_25 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_26 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_27 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_28 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_29 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_2A => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_2B => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_2C => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_2D => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_2E => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_2F => X"0000000000000000000000000000000000000000000000000000000000000000",
-- Address 6143 to 8191
INIT_30 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_31 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_32 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_33 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_34 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_35 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_36 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_37 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_38 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_39 => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_3A => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_3B => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_3C => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_3D => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_3E => X"0000000000000000000000000000000000000000000000000000000000000000",
INIT_3F => X"0000000000000000000000000000000000000000000000000000000000000000")
port map (
DOA => ROM_DOUT(i*2+1 downto i*2+0),
DOB => RAM_DOUT(i*2+1 downto i*2+0),
DIA => ROM_DIN(i*2+1 downto i*2+0),
DIB => RAM_DIN(i*2+1 downto i*2+0),
ADDRA => ROM_ADDR,
ADDRB => RAM_ADDR,
SSRA => '0',
SSRB => '0',
CLKA => CLK,
CLKB => CLK,
WEA => ROM_WE,
WEB => WEB(i/4),
ENA => ROM_EN,
ENB => RAM_EN
end generate BANK;
end Behavioral;
i use 16 BRAMs to make width:32 and depth:8192 Dual Port RAM.
every BRAM is 8192 * 2, with all brams i get 8192 * 32 RAM
one port uses MCU ROM, other port uses MCU RAM.
how can i make right .bmm file now ?
fpga is XC3S400A
thank you for suggestion.
01-05-2010 04:14 AM - edited 01-05-2010 04:16 AM
even if use memory/....., it is error yet.
BUS_BLOCK
Memory/bank[0].BRAM [31:30];
Memory/bank[1].BRAM [29:28];
Memory/bank[2].BRAM [27:26];
Memory/bank[3].BRAM [25:24];
Memory/bank[4].BRAM [23:22];
Memory/bank[5].BRAM [21:20];
Memory/bank[6].BRAM [19:18];
Memory/bank[7].BRAM [17:16];
Memory/bank[8].BRAM [15:14];
Memory/bank[9].BRAM [13:12];
Memory/bank[10].BRAM [11:10];
Memory/bank[11].BRAM [9:8];
Memory/bank[12].BRAM [7:6];
Memory/bank[13].BRAM [5:4];
Memory/bank[14].BRAM [3:2];
Memory/bank[15].BRAM [1:0];
END_BUS_BLOCK;
END_ADDRESS_SPACE;
END_ADDRESS_MAP;
01-05-2010 04:21 AM
03-18-2010 10:03 PM
hi i have use bram to my program but i dont have any idea please can u suggest ant doumentation or tutorial having example using bram
i hope u will reply
