yf201306
How to run ISE's Tcl file in cmd window
  I meet a problem when running the Tcl file in ISE. The details are as follws: we know that there is a "Command Prompt" in ISE, we can run Tcl files in that window. Now I would like to run the Tcl files in cmd window, so I input the same commands which are okay in "Command Prompt", but the commands run error in cmd window. Thus, I hope someone can tell me how to solve this problem, thanks for any reply!
rajeshkhanna
Please go through the following link.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/devref.pdf
yf201306
Thank you!
