How to save hardware manager configuration?
I have a configuration memory device, which I can add in the hardware manager, but it doesn't  remember it next time I open it.
Similarly, somehow suddenly the hardware manager started looking for my Probes file in a wrong location. Now I have to manually point it to the right location every time I open the hardware manager.
Re: How to save hardware manager configuration?
Its a very impotant question! It is a pity that it has not been answered. I also have to add the device each time, add files Are though it is impossible to finish ???
@jack1977 Can you consider using scripted flow?
-Pratham
I would not want to use scripts. I have no time to learn scripting.
tell me how to save the configuration without scripts?
@jack1977 Script flow is the best and only way to save. You need not learn script to use it. Vivado will generate script for you just you have to source the script next time.
-Pratham
I not agree with you.
The best way when the developer is hidden startup script. He opens Hardwar manager, and it saved the installation last session.
Over flea way - to require the developer to save the settings of each session.
Well, the worst way - to use the scripts as scripting is not the task of the developer. Scripts is artifacts.
I agree, if you use scripts to automate some specific action. but saving the configuration are not specific.
Your arguments?
