xilinx-zhaosheng
How to simulate the Vivado engineering IP core in system generator environment
A complete Vivado under the FPGA project (contains a lot of Vivado IP core), how to import into the system generator environment simulation
balkris
I would recommend you to create Sysgen design with using sysgen blocks. Sysgen design using the same IP from IP catalog . In case you want to import other RTL and IP catalog IPs for that you required use blackbox from sysgen block sets
Thanks and Regards
Balkrishan
