hegau
How to trigger a single bit in a bus with a trigger state machine?
I trying to trigger on a single bit in bus probe (std_logic_vector(31 downto0)) but there is a translation error
state myLoop:
	if (zusys_i/inputC1/myDataCollector_STATUS[13] == 1'bR) then
		increment_counter $counter0;
		goto myTrigger;
	else
		goto myLoop;
	endif
The error message is
 [Labtools 27-2056] Probe zusys_i/inputC1/myDataCollector_STATUS[13] not be found in current probe list
Is it possible to trigger on a single bit in a bus? And if yes, how?
Thanks in advance
arpansur
Hi @hegau,
You can try with 2 ways:
1. Create a user defined probe for that single bit and define user_defined_probe=1'bR
2. You can use
zusys_i/inputC1/myDataCollector_STATUS=32'bXXXXXXXXXXXXXXXXXXRXXXXXXXXXXXXX
Arpan
arpansur
Hi @hegau,
2. You can use
Arpan
