phonglt03
How to use Modelsim 10.1c with Xilinx 14.2
Dear all,
I'm using Modelsim 10.1c to simulate my Xilinx project and error "Library unisim not found" appearance when I use the unisim library in my vhdl code.
Could you help me, please?
Thank so much.
Best regards.
LTP.
bwiec
Did you run compxlib to compile your simulation libraries for that version of ISE and Modelsim?
www.xilinx.com
bwiec
www.xilinx.com
phonglt03
I've used following http://forums.xilinx.com/t5/Simulation-and-Verification/ERROR-Compxlib-267-COMPXLIB-sim-Unable-to-automatically-find/td-p/53819
and "Compile HDL Simulation Libraries" (command: compxlib -s mti_se -l vhdl -dir {D:/FPGA/HSDemod/$XILINX/<language>/<simulator>} -p C:/modeltech_10.1c/win32 -arch kintex7 -lib unisim -lib simprim -lib xilinxcorelib -lib edk -exclude_superseded -intstyle ise), but "Process "Compile HDL Simulation Libraries" failed.
phonglt03
Thank you very much, I've run Modelsim with xilinx.
BR,
LTP.
