Observer lxqvictor
How to use chipscope in vivado project?
HI all,
I'm using the Vivado 2013.4, in my project i want to use chipscope to capture data,
i did install the ise 14.3 which include the chipscope, the problem is :
there are no ICON and ILA IP that constituted chipscope in Vivado IP Catalog , i added the ICON and ILA that
generated in ISE14.3, but the Vivado2013.4 could not recognize them,
what's the right way to use  chipscope in vivado project? Could anyone  help me? Thanks.
ps: Vivado 2013.4 and ISE14.3 is not the same  version, Vivado 2013.4 is newer.
Re: How to use chipscope in vivado project?
Hi ,
As you are looking to migrate to Vivado logic debug cores please go through video training
http://www.xilinx.com/training/vivado/migrating-to-vivado-logic-debug-cores.htm
Achutha
VIVADO has lab tools which consists of ILA and VIO. Please use these cores in VIVADO.
The user guide at the link below could help you
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug936-vivado-tutorial-programming-debugging.pdf
Hi ,
Achutha
There is no need of using ICON core in vivado. Just generate and instantiate ILA core.
In Vivado IP catalog, search with keyword ILA, you will find IP. See below
Deepika.
Deepika.
Observer lxqvictor
Thank you very much.
Observer lxqvictor
Visitor currently
If you do wish to use your old chipscope cores in Vivado, you can still do this.
1) Using coregen, build your NGC's for the ICON / ILA / VIO
2) In Vivado, load the NGCs using the read_edif command (You will need to blackbox your component instantiation)
I have successfully used this approach on a couple of products now.  I find the Vivado debug flow/tools is cumbersome and problematic.  The vivado ILA is also bloated in comparison to the coregen/ISE ILA.
i try to use chipscope  in vivado to monitor the internal signals in real time, and i used ILA ip core to connect the required signal to the prob and add the ip core it to the top level module, and i generated the BIT file then open chipscope program and download the bit file to FPGA (successfully) , but no signals or waveform window appeared,,, so i can't monitor any signals
is there a missing processes ??
lxqvictor
Hi mo7amed_elhady@yahoo.com,
For detailed information you can refer UG908 'Vivado Programming and Debugging': https://china.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug908-vivado-programming-debugging.pdf
Tutorial is available here in UG936: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug936-vivado-tutorial-programming-debugging.pdf
Perhaps, you could have posted this query as a new thread.
Thanks & Regards,
Prathik
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Visitor elhady
Thank you
The video is 404'd
@achutha wrote:
Hi ,
Achutha
